Feb 22, 2016 5:07 PM UTC
PTC ARBORTEXT H/W & S/W REQUIREMENTS
We would like to ask about the hardware & software requirements for the "Advanced Print Publisher win32 11.1".
Thank you in advance
Lipiatos Alexandros
TimPhelpsAnswer
Feb 24, 2016 11:57 AM UTC
You may try those platforms, and find that the application works for you in that environment, but it is not supported.
PTC does not support or recommend the use of Arbortext Advanced Print Publisher with Windows 2003 or Windows XP.
Feb 22, 2016 5:59 PM UTC
alipiatos1-VisitorAuthor
Feb 22, 2016 7:56 PM UTC
Hi Vladimir,
According to the PTC APP 11_1_System and Soft.....pdf it is o.k. to install the s/w in an Intel Xeon CPU 3/00GHz with 2 GB RAM and Windows Server 2003, but when we try to install we take the process stop and give us the message "The operating system is not adequate for running PTC....WIN32 11.1 F000"
Feb 23, 2016 10:52 AM UTC
You can try to open a new case for PTC's tech support, here: https://www.ptc.com/appserver/cs/case/case_logger.jsp
