Jan 12, 2015 6:22 AM UTC
Publishing Engine in Arbortext Editor
Hello All,
While Installation of editor, it ask for the Publishing Server - If I do not have Arbortext Publishing Engine - What should be the option ?
- Can I get the trail version for Publishing engine only - it comes with Windchill server only ?
- Can I use the DITA OTK / Configure the OTK , if yes , how to setup /configure ? OR bydefault comes with the setup.
Thanks - MVK
    Jan 13, 2015 12:04 AM UTC
    If you do not have Publishing Engine then you cannot use the integrated publishing features of Arbortext.
    1. Publishing Engine does not require Windchill, it is a standalone servlet application running on top of Apache Tomcat. No publicly available trial that I know of. You may be able to ask your PTC representative or reseller if you can get a special 30 day test license.
    2. DITA Open Toolkit is not integrated with Arbortext.
    -Gareth
    -Gareth
    Jan 19, 2015 12:17 PM UTC
    Did your question get answered, or do you have further questions?
    - Tim
