Publishing Rules
Has anyone had any luck creating publishing rules for individual documents
and controlling the output directory and file name? Specifically, my
authors want to direct output to a specific folder and they want the
filename to be the name of the XML file. (Most important, I think, is the
filename.)
I can see (although I didn't try to change it) that there might be some
control using %n %u and %s but none of those values reference the source
XML instance's filename.
I'm wondering if there are options/parameters I can specify on the Advanced
tab that would do this. I can't find anything helpful in this regard in the
help, though.
Paul Nagai
    naglists1-VisitorAuthor
    By "individual documents" I do not mean one rule per XML instance. I just
    mean rules that would be used for a class of XML instances but the output
    would be a single document.
