Feb 9, 2026 3:24 PM UTC
Publishing TM Getting error
I am trying to publish TM that is around 8000 page. We can publish each chapter separately but when we combined into whole TM, we get this error .
PTC Arbortext Editor (Build 8.1.3.1-2) terminated unexpectedly at Fri Feb  6 15:21:47 2026:
[A17120] Assertion failed: size < TXF_MARK, file D:\jenkins\workspace\Adept_1\adept\src\pub\pub\edit\src\stortxt.cpp, line 534
Current ACL statement at "C:\progra~1\PTC\arbort~1\packages\main\_grhook.acl":264:
  264 [1]   return path
ACL function traceback at time of error:
#1   layout::format(doc=31, sourcedoc=31, sstype="", force=1) at "C:\progra~1\PTC\arbort~1\packages\main\_grhook.acl":264
#2   comp_pdf::pdf_postprocessing(doc=31, params=inParams[], interactive=1)
#3   compose::compose_for_type_int(doc=31, comp_type="pdf", interactive=1, inParams=inParams[], preprocessing_function="comp_pdf::pdf_preprocessing", dialog_function="comp_pdf::dialog_for_pdf", param_fixup_function="comp_pdf::pdf_parameter_fixup", postprocessing_function="comp_pdf::pdf_postprocessing") at "C:\progra~1\PTC\arbort~1\packages\tools\compose.acl":2672
#4   compose::compose_for_type(doc=31, comp_type="pdf", interactive=1, inParams=current_params[], prefn="comp_pdf::pdf_preprocessing", dialogfn="comp_pdf::dialog_for_pdf", paramfn="comp_pdf::pdf_parameter_fixup", postfn="comp_pdf::pdf_postprocessing") at "C:\progra~1\PTC\arbort~1\packages\tools\compose.acl":1761
#5   compose::compose_for_pdf(doc=31, batch_params=dummy[]) at "C:\progra~1\PTC\arbort~1\packages\tools\comp_pdf.acl":324
#6   compose_pdf() at "C:\progra~1\PTC\arbort~1\packages\tools\comp_pdf.acl":117
thank you
bfriesen
18-Opal
Feb 9, 2026 6:12 PM UTC
Just did a quick search of the PTC help
Looks like it has been asked before also with no solutions
https://community.ptc.com/t5/Arbortext/A17120-Assertion-failed-aptFalse-file-src-forsirtns-cpp-line/m-p/497907#M31261%3Fsource=search
https://community.ptc.com/t5/Arbortext/Error-A17120-Assertion-failed-size/m-p/231400#M16455%3Fsource=search
https://community.ptc.com/t5/Arbortext/blown-out-paths/m-p/190636#M13534%3Fsource=search
here are a couple from PTC support to look at.
https://www.ptc.com/en/support/article/CS410678?source=search
https://www.ptc.com/en/support/article/CS187410?source=search
Sotution:
Feb 10, 2026 3:24 PM UTC
Dear Customer,
Have you made any changes to this ACL? Did you customise this?
Manpreet Singh
Feb 10, 2026 4:06 PM UTC
Thank you Manpreet and bfriesen,
we have not modified any ACL. Per PTC support ticket https://www.ptc.com/en/support/article/CS410678?source=search
I have test version of Editor 8.3.1. Ran thorough the same manual, I got signal 22 error.
Feb 12, 2026 3:47 PM UTC
Hello Mohit,
Did you also face the same error (along with what you mentioned above) mentioned in that article?
Manpreet Singh
11-Garnet
May 14, 2026 8:11 PM UTC
We have seen very similar behavior, specifically working on large documents. The issues started specifically with the upgrade to Editor 8.0 and have persisted ever since.
We have also encountered this when publishing individual chapters, depending on their size, and we work with some very large documents. Our only workaround has been to use queued transactions. We’re unalbe publish the full manuals affected by this issue (even using queues), but we are able to use queued transactions for the larger chapters which also fail, and then publish the others individually using our standard methods.
Will you update here if you do get an answer?
