Publishing xml document via publication structure
I'm trying to publish xml documents (Dynamic Docs) by creating a structure (Publication Structure) through Arbortex Publishing Engine.
The problem is, when this xml document is processed by APE, the resulting output PDF is containing only file name on top of pages and rest of the PDF is blank.
I'm also not able to see any graphics.
Hello Surya,
What type of document you're inserting in a Publication Structure, is it DITA type or Axdocbook type?
If it is Axdocbook type, then it is required some deep level of stylesheet development. If it is DITA type document then it does support.
If it is a DITA type document, then does this standalone document gets published from Windchill SIM?
Manpreet Singh
Community Moderator
October 16, 2024
Hello @SR_10678621,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
