Nov 12, 2010 6:28 PM UTC
Quick FOSI Question
We haven't had to change our FOSI in years (aside from slight
modifications) so I'm a bit rusty.
I'm hoping someone might be able to answer this quick question before
I inevitably figure it out.
Given two elements:
<problem id="p_123"><para>This is some
text</para><some-other-elements-here/></problem>
and
<problemref linkend="p_123">
I would like to have the para text from the ID node shown after the
problemref element in Arbortext.
I setup my fosi as follows:
<e-i-c gi="problem">
<charlist charsubsetref="block">
<indent leftind="@12pt" firstln="*"></charlist>
<att>
<specval attname="id" attloc="problem" attval="#ANY">
<charsubset>
<savetext textid="xref-formatted.txt"&lt;br"/>conrule="<problem.fmt>,#CONTENT,</problem.fmt>" xrefidtag="problem">
</charsubset>
</att>
</e-i-c>
<e-i-c gi="problemref">
<charlist inherit="1" charsubsetref="inline"></charlist>
<att>
<specval attname="linkend" attloc="problemref" attval="#ANY">
<charsubset>
<usetext source="#XREF(linkend,xref-formatted.txt)"></usetext>
</charsubset>
</att>
</e-i-c>
Now, the issue I'm having is that #CONTENT gives me all text within
the problem, but I really only want the text within the para. Is
there a simple way to just pull the <para> text?
Thanks in advance,
keith
    Nov 12, 2010 6:58 PM UTC
    Give the para tag an id. The xref out to it. You may have to have two xrefs but it should work.
    berard1-VisitorAuthor
    Nov 12, 2010 7:14 PM UTC
    That's certainly an option, but it might be more tricky since we use
    <para> tags all over our content, and there would have to be some ACL
    overhead to strip the IDs if copied/pasted into a different context.
    As the model works today, when the user tries to insert a <problemref>
    tag, they are presented with a dialog that shows all available
    problems.
    I was hoping there might be more of an xpath-like way to extract just
    the content I need.
    keith
    On Fri, Nov 12, 2010 at 12:58 PM, Young, Sindy R
    Nov 12, 2010 8:01 PM UTC
    Keith,
    In your <e-i-c> I'd change the 'gi' from "problem" to "para" and then add a 'context' of "problem". That should gather the text of the paragraph contained in the problem
    Lynn
    > problems.
    > the content I need.
    > keith
    Nov 12, 2010 8:34 PM UTC
    Aah, perfect!
    I stare at "e-i-c" all day, and seldom think to expand it out to
    "Element in Context", which does exactly what I need.
    keith
    Nov 12, 2010 9:34 PM UTC
    Good eye Lynn
    Nov 14, 2010 4:13 PM UTC
    Sindy,
    Thanks.
    I'll take FOSI to FO ANY DAY OF THE WEEK. 😄
    Lynn
    ---- "Young wrote:
    > Good eye Lynn
