quickly truncate callouts in IsoDraw?
Have numerous callouts that have the part name and the "long version" of the part number, i.e.
WASHER
(01-030, 79-21-11)
would like to have a way to click on the callout, hit a macro or hit a button that quickly changes to the "short version" of the part number
WASHER
(01-030)
It will always be the same pattern. Find the comma, delete it and everthing after it until the paren.
have been playing with:
selecting the layer with callouts on it
making it the only visible layer
selecting only text that contains "("
exporting selection as text file
going to an outside text editor to do find&replace
importing them back into IsoDraw
Got to be a less klunky way to something so simple?
Just delete the two lines 'Select None' and 'Select if Type is "Text"' at the start of the macro. It will then only run on what you have selected. In regards to not working on all the text elements, I'm not sure at this point. I ran it against the sample provided and it worked on all three. Can you post what you tried it on if it is different?
Gary,
Its very easy,
Just send one sample .iso file.
attached is sample file
Bolt, Washer, and Nut
would be great if I could select a callout, hit a key or click a button and truncate it to the short form
All efforts appreciated..
Here is a macro to do what you want. It selects all text elements and then searches for a comma. If found it removes the comma and all remaining text and then applies a closing ")" at the end. Simple but effective.
Macro Text_Clean
Define E1 as Element
Define Where as Integer
Define Output as String
Select None
E1 = ActiveDoc.FirstSelectedElement
While (Exists(E1) = True)
Where=Find(E1.Text.String,",",1)
If(Where <> 0)
Where=Where-1
Output=Left(E1.Text.String,Where) + ")"
E1.Text.String=Output
End If
E1=E1.nextSelectedElement
Select None
End While
End Macro
