read only documents
I am trying to temporarily change a read only document to insert a PI. I set rochange to on and then go to change the document, but get an Arbortext message saying that I cannot modify the document because it is read only. Not sure what I am doing wrong. This used to work in version 4.3, but no longer works in 5.3. Anyone have any clues. Thanks.
    If you are using 5.3 on Windows 7 it might have something to do with Windows 7's increased security. You might have to launch Editor as Admin before you set rochange.
    jbaklayan1-VisitorAuthor
    Actually the rochange seems to work. It seems to be a problem with the modify_text_entity. When the rochange is set to on, the modify_text_entity still doesn't work in read only documents.
