May 28, 2014 3:27 PM UTC
Recording query operations in macro (Arbortext Editor 6.1)
Hi all,
I'm trying to record a macro in Arbortext Editor. I need the following:
1) Insert markup pop up window;
2) Choose query from bottom drop down list (I've modified my dcf file to allow datamerge);
3) Select the only query name I got;
4) Click on 'Insert' (or double click on name selected on query name at point 3).
When I start macro recording, the only instance I get in my macro file is '#InsertMarkup' and no more. Also, trying to run it, it doesn't show the insert markup window, although permitted in current position.
I wonder if it is possible or not.
Any help?
Max
    Max_at1-VisitorAuthor
    May 29, 2014 9:10 AM UTC
    I'm trying to do the same just using a ACL script, called by a customized menu, to avoid any macro management.
    I used the insert_tag("atidm:query").
    It calls a general query and shows a query attribute popup. I'd like to call query WITH attributes needed (queryName etc.), but I can't understand how to do that. If I add anything else the simple atidm:query instance, editor just doesn't add any string, neither error messages.
    Thanks.
    Max
    May 31, 2014 7:02 PM UTC
    Are you using oid_modify_attr() to give a value the the queryName attribute?
    oid_modify_addr(oid,"queryName","YourValueForqueryName")
    Jun 3, 2014 1:22 PM UTC
    Thanks for answering.
    No, I didn't, I was using just a call to:
    insert_tag("atidm:query");
    in my acl init script file.
    Could you please explain me how to use your line of code?
    Manuals don't help so much in term of samples...
    Thanks.
