Refresh generated text with ACL?
Sometimes when I'm inserting elements using ACL, the gentext doesn't update until I manually click the Update GenText button. I didn't see an ACL command that does the same action as the button, but I'm sure there must be one.
Does anyone know how to do it?
Steve
    18-Opal
    November 30, 2012
    Hi Steve--
    ShowGentext should do the trick.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Interesting Clay, I'll have to try that.
    We had some problems with refresh as well, so now I have a method that
    calls the following two:
    set gentextcurrent=off
    set gentext=on
    - keith
    The following two may also "play" nice.
    Redisplay
    RevertStylesheet (an alias for the stylesheet_revert() function)
