Regarding ISodraw
Hi All,
Can anyone help me to solve the below questions as I am very new to Isodraw and Macro language.
Thanks in advance.
Scope: I have hell of .iges files and need to explode the assemblies,illustrate them in Isodraw 7.3 or Isodraw 6.1 and save them as as .cgm and .JPEG formats.
Question 1: Whn I open .iges files(Created from catiaV5 i guess) and select single bolt for example, all the bolts in the model are getting selected and getting exploded at a time but i need to select individually as they are grouped in original catia file.Is there any option to select them individually and then explode.Please help.
Question 2: When i record a macro, where these macros will get stored in Computer for Windows XP Service pack2. Can anyone send me macro to export all the .iso files to .cgm and .jpeg at a time.Please send me macro for Isodraw 6.1 or Isodraw 7.3 or Isodraw 7.0 Cad process. And also how to edit the macro if in need to change anything.
Here is a basic CMG/JPG export macro
It will use the setting that are stored in the IsoDraw 7.3 Preferences.prf file
Macro Export CGM JPG
Define docname as String
Define path as String
path=stripFileName(activeDoc.path)
docname = stripExt(activeDoc.name)
Export path+docname+".CGM" "CGM"
Export path+docname+".jpg" "jpeg"
End Macro
Depending on your network set up the macros maybe stored in a couple of different places
C:\Program Files (x86)\PTC\Arbortext IsoDraw 7.3\Program\Macros
or
C:\Users\YOURNAME\AppData\Roaming\PTC\IsoDraw\Macros
Hope this helps
