Relative path when inserting an image in Arbortext Editor
Suppose my xml document is at c:\temp\xml
If I insert a graphic which is stored at the same level of my XML document, the result is :
<inlinegraphic fileref="graphic6.png"/>
If the graphic is in an image directory at the same level, it becomes :
<inlinegraphic fileref="images/graphic6.png"/>
Now, if I want to reference an image that is one level down in my tree structure (temp/shared), A/E switch to absolute path and the result is ;
<inlinegraphic fileref="c:\temp\shared\graphic6.png"/>
So my question : is is possible to hava a relative path (../shared/graphic6.png) instead of an absolute.
Any idea is welcome, Pierat
    Answer
    November 18, 2010
    A little ACL can help you here. I use the insert_tag_after callback to modify the attribute value for the system path when authors insert an image element.
    doc_add_callback(0,'insert_tag_after','img_pathfix')
    function img_pathfix (doc,tagname,op)
    if(op ==1)
    if(tagname == 'image')
    #response("found an image")
    o = oid_attr(oid_caret(),'system-path')
    oid_modify_attr(oid_caret(),'system-path',universal_file_name(o))
    I use this function to change mapped network drive paths to UNC paths, but after capturing the attribute's value with o=oid_attr(oid,attname), you should be able to modify that value any way you feel necessary and use the oid_modify_attr(oid,attname,val) to "fix" the value.
    There is also an insert_tag callback, but it triggers before the markup is inserted, so it's ineffective for modifying an attribute since the element hasn't been inserted yet.
    Hope this helps...
    -Jason A. Buss
    Answer
    November 18, 2010
    if(op ==1)
    Hope this helps...
    -Jason A. Buss
