Nov 20, 2017 9:49 PM UTC
Release management strategy for Dynamic Documents
Description:
I have DITA bookmap with topics (User Manual). I load them to Windchill. I get dynamic documents:
  • DITA bookmap A.1
  • topics...A.1
Then I publish them to PDF and then print it. I give printed manual to my customer(1).
Then I change topic_1 from this manual:
  • DITA bookmap A.1
  • topic_1 A.2
  • other topics...A.1
Then I republish User Manual to PDF and print it. I give printed manual to another customer(2).
This is another User Manual than have customer(1).
Then customer(I don't know which - 1 or 2) calls to our tech support and says that he finds the error in our User Manual.
How to identify which User manual does he mean? How to find it in Windchill?
If I have 1000+ bookmaps, 10000+topics with 100+ versions, 10000+ customers.
My question is about what metadata from Windchill I should use to track my printed documents with their Windchill objects.
I only see this way:
Use version attribute of Dynamic Document from Windchill(burst settings) in DITA bookmap  and always iterate root DITA bookmap object when topic is changes. It's hard manual work. For example, if topic is used in 500+ maps.
Are there any another ways?
Nov 21, 2017 9:16 AM UTC
The combination of the Windchill object ID and "version.revision" gives you the unique identifer from a data perspective. If you use the title of the topic or even the topic filename then the problem you have is that the same topic name could be used all over the place (e.g. "Introduction").
Nov 21, 2017 9:40 AM UTC
Hi,@GarethOakes.
"The combination of the Windchill object ID and "version.revision" gives you the unique identifer from a data perspective." - No. See my description.
  • DITA bookmap A.1
  • topic_1...A.1
  • topics..A.1
Then I publish DITA bookmap A.1 to PDF and then print it. I use "version.revision" in PDF(A.1). I give printed manual to my customer(1).
  • DITA bookmap A.1
  • topic_1 A.2
Then I republish DITA bookmap A.1 to PDF and print it. I also use "version.revision" in PDF(A.1). I give printed manual to another customer(2).
So my customers have same unique identifers of User Manual (DITA bookmap A.1) with different content (topic_1 A.1 and A.2).
Nov 21, 2017 9:44 AM UTC
You misunderstand. The Windchill Object ID is not visible in Arbortext (or is perhaps under the dialogs somewhere?). It is a random ID like "01324512344". It has no relationship to DITA topics, but is the ID used for storage in the underlying database. You can retrieve it and map it to XML attributes using the 2-way bursting rules.
