bfriesen
18-Opal
May 28, 2019 4:07 PM UTC
Remap CTRL+W to a different Key?
One of our authors was wondering if
CTRL+w
can be mapped to something else in editor or removed.
When trying to select using
CTRL+E
they are closing the active window.
Thanks Bryon
18-Opal
Jun 4, 2019 7:01 PM UTC
map ctrl-w {}
bfriesen
bfriesen18-OpalAuthor
18-Opal
Jun 4, 2019 7:11 PM UTC
Thanks Clay, does this need to be put into an acl and in the init folder?
Bryon
18-Opal
Jun 4, 2019 7:42 PM UTC
If you want it to apply for everyone, then that's probably easiest. If you already have an init.acl startup file, you can just add it to the existing file.
If you discover that it doesn't work from init.acl, you may need to move it to a file in editinit instead, so it will load later in the startup process.
If someone just wants a quick fix for the current session, they can just type it into the command window.
