Nov 1, 2017 5:59 PM UTC
Remote desktop connection using AE licenses
My pc at the office has a locked license. When I access my office pc from my home computer apparently I am using a floating license.
So basically I am using both locked and floating licenses. Consequently, less licenses available to other users.
Why does the license type change when accessing through VPN? I am connecting directly to my office pc where AE is installed. Should it not use the locked license?
Nov 1, 2017 9:00 PM UTC
Arbortext versions 6.0 and higher use the Flex licensing mechanism. Node-locked (fixed) Flex licenses cannot be used with remote desktop connections. Therefore, your application is looking for and using a floating (concurrent) Flex license when you are remoting in to your machine.
bfriesen
18-Opal
Nov 1, 2017 8:27 PM UTC
Do you use the styler version of editor? I find that I use our copy of styler and if I open a topic from the map it opens it in editor. Which uses up a locked version of styler and a floating editor.
Bryon
