Nov 15, 2019 1:55 PM UTC
Removing Entity after pulling in the text
When using Arbortext 6.0, can you remove the entity files from the XML file after pulling in the text from the entity?  Basically using entities to share content and upon publishing remove all entities and keep the content.  Which basically flat files the xml file.
Nov 16, 2019 9:43 AM UTC
Yes, Arbortext is able to flatten files in this way but it's not available through the menus. You would have to write a small script to do the work. Look up the doc_flatten function in the Arbortext Help Center.
Nov 19, 2019 12:18 PM UTC
