repeat title in 2nd column
I have a two-column layout in which I have mulitple categories of content. Each category is given a title using xsl:text. When the content of a given category flows over to the 2nd column, I want the category title to print above the content that has flowed over.
Thanks.
    Bev is working on the Army 40051-2A style sheets.  From what this sounds like, it is the double column of the work package initial setup.
    BTW, I am no longer involved in the 40051 style sheet effort. I will be starting a new job on 20 Dec.
    Give Bev all the help you can folks.
    Lynn
    > Thanks.
    Grats...as maddening as it is to be on this end, I bet I'd rather REMAIN on the receiving end...
    John T. Jarrett CDT
    Senior Tech Writer, Integrated Logistics Support,Land & Armaments/Global Tactical Systems
    T832.673.2147 | M 832.363.7234 | F 832.673.2376| x1147 | -
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
