Aug 1, 2014 5:09 PM UTC
Restoring a File
If one of our XML files, 123456.xml, contains change-tracking markup, we write a copy of the file, 123456.xml.redline, and then accept all of the changes to the file before further processing and placing the file in a watch folder to be picked up by our typesetting system. After that is done we want to restore the version of the file that contains the change-tracking markup. For many years using the Unix version of Arbortext Editor (or its predecessors), we would copy 123456.xml.redline to 123456.xml and the edit -current to open the file with change-tracking in the open editing window. Now that we have switched to Windows (running v6.1 M010), after issuing the edit -current command, the file (123456.xml) does not display the change-tracking markup. However, if I open 123456.xml in an ASCII text editor, I do see the change-tracking markup in the file. In order for the change-tracking markup to be visible again, I have to completely exit and re-start Arbortext Editor and re-open 123456.xml. Does anyone know of way to get the restored version to display without having to exit Arbortext Editor?
