Jan 17, 2013 1:48 PM UTC
Restoring cursor position
Good day!
Let us mark cursor position in the form of "|" sign.
For example, we have the following node in Arbortext Editor 5.2.
<node1>This is a sim|ple text.</node1>
Then my Java plugin encloses part of text with a "b" and "i" nodes:
I want to restore the cursor position relatively to "node1", but the following code will not help me:
pos = oid_caret_pos(oid) // oid of the node1
goto_oid(oid, pos)
oid_caret_pos treats each non-text object (that is, markup, equations, tables, graphics) as one character.
    18-Opal
    Jan 17, 2013 4:29 PM UTC
    Hi Ilya--
    Right, oid_caret() and oid_caret_pos() won't help in this instance,
    since you are modifying the content after storing the location, which
    will throw the pointers off.
    Probably the easiest way to manage this would be to use some kind of
    marker like a PI to take the place of the caret, and then using that to
    find the caret position after modifying the content, something like
    this:
    # insert caret marker
    insert(");
    local caretoid = oid_caret();
    # make changes
    mark_up_text(oid1);
    # restore caret
    goto_oid(caretoid);
    oid_delete(caretoid);
    HTH.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    Jan 30, 2013 3:04 PM UTC
    Thank you for this trick, it works fine.
