Retrieve tag value and assigning to a variable (APP)
Hi Everybody!
There is any way to I retrieve the tag's value and assigning it to a variable? Actually, I've a xpath tag and I need to get its value.
The tag is this:
<_gte:XPathString expr='_acl:eval(\"$ENV[&#x27;Test&#x27;]\")'>&lt;/_gte:XPathString>
What you need to consider is "where" the variable information is to be stored. This may also be referred to as the variable scope.
1. Global - across entire application.
2. Document - specific to current document.
3. Format - specific to current formatting pass.
4. Page - specific to current page.
5. Element - specific to current tag.
Your #1 is Global-scope, your #2 is Element-scope and your #3 is also Global-scope and indeed scoped at the o/s process level too. APP provides "counters" which are Format-scope and they tend to be used for what I think you are attempting.
You will also find the Global-scope Javascript variables also act as Format-scope when they are used inside formatting tags. However this behaviour is only for scalar variables, not for objects or arrays.
This looks like Source Edit of an APP Stylersheet. Is that correct? If so, you don't "save" a tag's output anywhere. It is written to the page.
As I mentioned in the other thread, this doesn't look like the normal way to do things. If you can explain what you are trying to achieve there is probably a better way to do it.
rboneti1-VisitorAuthor
Thank you Gareth!
I thought it was not possible either.
In fact, I need to pass a value from one element to other, using APP, because it value needs to be retrieve in OnExit function. To pass this value, I've found and tested 3 ways:
1 - I created a external js file, and use get/set functions to do a global variable.
2 - I used the formatting.evaluateXPath( 'x3b2:set-userdata( "_temp_hasbefore_", "1" )' );
3 - I used the acl ENV like this: formatting.evaluateXPath( '_acl:eval( "$ENV(\"some_text\")=\"some value\"" )' );
All of these can keep a information and be retrieved in another element. But in my case, I have to do this in the following struct:
<figure>
<table>
</table>
</figure>
I've set the value in the table and gotten it in OnExit of figure.
When I use the third option to keep the informations, it only works well if I retrieve by tags.
It works:
It doesn't:
formatting.evaluateXPath( '_acl:eval( "$ENV(\"some_text\")" )' );
