Run ACL code for many documents
Hello adepters,
I have document with tag "sdc" - System Difference Code, which content is
"A". I need to change content of all instances of tag "sdc" from A to B.
I wrote simple code which produces such work.
But, I have hundreds or thousands documents with sdc=A. It is not reasonable
to make such work manually. I need to run my ACL code for many documents
from a list of files or for all documents in directory.
Does somebody knows, is it possibly to produce by ACL:
- open document (file name from a list of xml files)
- run ACL
- save and close document
- open next document from the list of files, and so on?
My code for reference for one document:
function sdca2b()
# Replace content of SDC elements from "A" to "B"
# find all SDC and put oids into array
$sdc_array = xpath_nodeset (sdc_nodes,"//sdc");
# Get markups SDC from array
for (i=1; i <= sdc_array.length; i++ )
goto_oid(sdc_nodes[i]);
if (oid_content(sdc_nodes[i]) == "A")
#mark and delete content of tag sdc
mark -noselect -noinvert begin;
goto_oid(sdc_nodes[i], -1);
mark end;
delete_mark;
# insert string "B"
is "B";
Thanks for all in advance,
Alexander Neder
+7 495 737 7878,
Department Manager,
PTS,
16, Marxistskya, Moscow, Russia.
    18-Opal
    August 26, 2010
    Hi Alexander-
    Sure, you can do this. Use the glob() function to get your list of
    items, then iterate over it, something like this:
    local $files[];
    glob("*.xml",$files);
    # untested code, debugging is left as an exercise
    for ($file in $files) {
    local $doc = doc_open($files[$file]);
    current_doc($doc);
    sdca2b();
    doc_save($doc);
    doc_close($doc);
    HTH
    --Clay
    aneder1-VisitorAuthor
    Hello Clay,
    Good! It does work!
    The only problem was incorrect quotes in glob("*.xml",$files) - probably
    mail client repairs them.
    Thank you very much!
    Final code is:
    function all_files()
    local $files[];
    if (file_directory("C:/work/mydoc") == 1)
    {eval "c/work/mydoc is a directory" output=>*}
    glob("C:/work/mydoc/*.xml",$files);
    current_doc($doc);
    sdca2b();
    doc_save($doc);
    doc_close($doc);
    function sdca2b()
    mark end;
    delete_mark;
    is "B";
    Sincerely,
    Alexander Neder
    +7 495 737 7878,
    Department Manager,
    PTS,
    _____
    18-Opal
    August 27, 2010
    Hi Alexander-
    Great, glad it works for you. Now that you've tested it, you can take
    out the comment about it being untested code. 🙂
    --Clay
