Nov 30, 2011 9:52 PM UTC
Save and Open in OpenOffice (sh command)
I have this code:
local i;
local dir;
local sAppPath;
for (i = 0; dir = get_custom_dir(i); i++) {
if (match("$dir",'bcfi')){
sAppPath = "$dir";
break;
local sTmpSave = "$sAppPath" . '\tmp\currexport.xml'
save_as "$sTmpSave";
sh 'C:\Program Files (x86)\OpenOffice.org 3\program\swriter.exe $sTmpSave'
It does save the current document in a custom application directory. So far ok, now i'm trying to start OpenOffice, no problem, bet then it fails to open the just saved XML document. I can not figure out the way I should pass the sTmpSave variable to the sh command, please help!?
Regards, Geurt Lagemaat
