Feb 17, 2011 3:27 AM UTC
Setting a context specific attribute to read-only ?
Hello everyone,
Just wondering if anyone know how to set an attribute to read-only -
in a specific context.
In the .dcf I can set>
<attributeoption attribute="attname" dialoghidden="no" readonly="yes"/">
But I need to set it at a specific level. The same @attname at the
root level needs to be editable.
thanks,
Tracey
    Feb 17, 2011 11:08 AM UTC
    Offhand, I'd say your best bet is to intercept the opening of the
    Modify Attributes dialog using a "create" window callback. This will
    give you the opportunity to examine the current element and make the
    relevant attribute(s) read-only by disabling the corresponding XUI
    controls.
    -Brandon 🙂
