Apr 15, 2015 7:28 PM UTC
SGML and PDF bookmarks
I have a DTD and FOSI provided by a customer. Their FOSI has custom pdf bookmark tagging in it (<atidmd: etc.,=" etc.).=" everything=" else=" seems=" to=" work=" fine=" except=" for=" these=" custom=" bookmarks=" when=" i=" compose=" the=" book.=" i=" am=" using=" print=" composer=" and=" file--="> Compose--> Pdf File. I've tried with distiller="on" and "off".
I read in an older thread a comment from someone saying that custom bookmarks are not possible using Print Composer, but only when using PE environment.
Is this true?
KM
    Apr 15, 2015 7:33 PM UTC
    Hi Kim,
    Hopefully someone will reply directly to your question about PC vs. PE. I
    switched to PE so long ago, I am not 100% aware of the PC details anymore
    (that and what was true when I switched may not be true anymore).
    What I do remember is that to get PDF bookmarks out of PC used to require
    identifying elements as division elements in the .dcf. So, do you have a
    .dcf? Do you see content in the .dcf like:
    <elementoption category="division" element="chapter"/">
    If not, try adding that and see what you get.
    On Wed, Apr 15, 2015 at 12:28 PM, Kim McCain <->
    wrote:
    > Hi,
    > bookmark tagging in it ( Compose--> Pdf File. I've tried with
    > environment.
    > Is this true?
    > Thanks,
    > KM
    Apr 15, 2015 8:01 PM UTC
    Hi Kim,
    Composer works for me. I've attached the section of my book that includes information on PDF bookmarks.
    Good luck!Suzanne Napoleonwww.FOSIexpert.com"WYSIWYG is last-century technology!"
