Shaded Background in the table header row.
I am using AT Styler (APP Engine) for the PDF output. I would like to add grey shaded background for the table header rows.
For this i created Property set (i.e. copied the default "box" and modfied as "shade")> I added the APP Source edit with the "fill color". It is not worked out.
Also it's throwing composition error. I have attached the Event Log.xml.
Could any one help me on this.
Is the APP Source Edit for Property set is OK? or any other method in Styler was there to modify the background color of header row.
