8-Gravel
Sep 21, 2016 10:23 AM UTC
shortcut grid
Hello! Is there a shortcut to change the grid from view to isometric?
Thanks for your help!
Sep 21, 2016 7:23 PM UTC
In the attributes window there is a button for 'Grids'. You can toggle between plane view and isometric from there.
If you wanted it simpler you could make a small macro using myDoc.active_grid to toggle the grid.
