Jul 7, 2015 6:36 AM UTC
show popup for colored text
     As per my requirement I have changed the colored of a text and I need show popup when I right click on that colored text with some suggestions . Is there any functions or commands that I can use from ACL ?, Request to provide some help on this please.
    Please find the attachment for reference
    Jul 7, 2015 9:51 AM UTC
    Hi Prashant
    I made simple sample code for your requirement.
    Please check the attatchment files.
      ptc_init : copy into 'Arbortext Editor/custom/init' folder.
      ptc_menu : copy into 'Arbortext Editor/custom/scripts' folder.
      ptc_check_word : copy into 'Arbortext Editor/custom/scripts' folder.
    Note :
    - In this logic, you have to use 'Touch Up' in order to change the color.
    - You can see 'Suggestion Word' menu in bottom of context menu.
    - When you right click on colored text, context menu is activated.
      Otherwise context menu is disabled.
    - I used a simple message  box to display suggestion words.
    - However if you need a complex UI to show suggestion word, you can use 'XUI'.
      (Please find 'XUI' in Help Center)
    Hope that helps !
    Kim, Joon O
    prao1-VisitorAuthor
    Jul 7, 2015 12:11 PM UTC
    HI Kim,
                Thanks for the reference code , I changed accordingly but the "suggestion word' is disabled every time. I am not able to trace it out, could you please suggest on this.
    Prashant
    prao1-VisitorAuthor
    Jul 7, 2015 12:18 PM UTC
    HI Kim,
                It working fine now, thanks. Please ignore my previous mail.If I want to show only "Suggestion Word" in the context menu means do I need disable any function ?
    Thanks.
    Prashant
