Apr 28, 2015 11:49 AM UTC
Sorting attribute values in Modify Attributes dialog
Hey folks,
I have a question about sorting attribute values.
In the Modify Attributes dialog, the values in dropdowns are sorted alphabtically by default. Is there a setting to turn the sorting to manual?
Many thanks,
-Jeff
    Apr 28, 2015 12:20 PM UTC
    Jeff,
    As I recall, there is no way to sort them. I asked this several years ago. I set my DTDs up so ‘required’ values were first, only to have them show up in the list.
    If nothing else, it would be nice if we could have the attribute list organized by ‘required’ then optional. Might confuse the authors for a while, but to me I think better than searching for that missing required entry.
    Lynn
    Apr 28, 2015 1:30 PM UTC
    Thanks Lynn and the others who emailed.
    I guess there's no magic bullet on this one.
    Apr 28, 2015 1:48 PM UTC
    So, does set modifyattrssort=off no longer work? It used to toggle between alpha sort and order of declaration.
    Apr 28, 2015 1:52 PM UTC
    According to the documentation modifyattrssort is only for sorting the order of attributes in the dialog for SGML.
    For XML document types attributes are generally listed in alphabetical order. If the attributes are categorized, you can use the sort attribute for ModifyAttributeCategory in the DCF file to sort them. For SGML documents, attributes names are listed in the order they are defined in the document type by default. To list the attributes alphabetically, set the Advanced Preference modifyattrsorted value to on.
    In Reply to Jason Buss:
