Spanning
I give up!
I have an element that seems to be spanning the two columns when I don't want it to span. I have span=2 on this element and it's parent element. I have balance set to off. Is there another tag that causes something to break across the two columns?
I have tried every combination that I can think of.
Ellen
    is Jepp hiring?
    _____
    did you try deleting the span on this element and letting it inherit from the parent?
    That was it.... I had TOO many spans!
    Ellen
    Try sending these inquiries to the individual. Don't reply to the message. The whole group gets your question when you do this. You don't look like a very good job prospect if you can't figure this out.
    I'm sending this to the group so you don't get a whole lot of individual messages similar to this one.
