Jul 28, 2011 7:36 PM UTC
spellcheck and brk tags
I know the spellcheck improved after 5.1, and can detect when there are
missing spaces between elements. Is there a way (e.g., editing .dcf) to turn
off that boundary around the element <brk> check. I do not want to add
spaces near the <brk> tag, but I do not like it looking like the words
around the <brk> tag are misspelled.
d
    18-Opal
    Jul 28, 2011 7:43 PM UTC
    Hi Doug-
    Try adding an <elementoption> element in your DCF for the "brk" tag (if
    it's not already there), and set spellCheckingNewWord="yes". I think
    that should do what you want.
    <elementoption element="brk" spellcheckingnewword="yes"/">
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Jul 28, 2011 9:27 PM UTC
    beautiful, works... I was using those settings, but added a few others
    attributes and that did not work. I reset them all, and only use
    spellCheckingNewWord then it worked.
    d
