Jan 11, 2017 12:46 PM UTC
Stange behaviour when deleting letters in some tags (Abortext 5.4 M110)
Good morning to all of you.
I would like to know if some of you meet the same problem than me.
In some tags (item tag for example in my case), when I want to delete a letter with the delete key (not the backspace key), the following whole tag is deleted !
If I want to delete the wanted letter I must highlight the letter with shift key and arrow and then, use the delete key.
I can use backspace key, even sometimes the problem occurs.
It's a strange behaviour that occurs with some tags and not all the tags and it's very dangerous because I cross checked a colleague work that deleted a whole item tag without realizing it.
I wondered if it was related to the schema or FOSI but I don't see what could be the relation between them ?
Thank you by advance for your replies.
Best regards.
