Nov 16, 2018 2:59 PM UTC
Strange behavior with latest 40051-2C config files
I've been using Arbortext 7.1 to author documents that use the 40051-2C XML architecture.
The latest version of the configuration files are acting strangely.  Apparently, you can insert any tag anywhere.  That is, when I click Insert > Markup for any tag, I get a big list of tags that starts with a.statement and ends with zip.
In some ways, this looks like a good thing, but it will probably cause problems somewhere.  I'm wondering if this was intentional, accidental, or maybe a problem at my end.  I've done a WinMerge comparison of the last two versions of the config files and can't find any clue to what's going on.
I access the config files from https://pubsweb.redstone.army.mil/DTD-FOSI/Webpages-60/ALLDTDs-AMCOM.html.  It's the 40051C 6.0 link at the top that's dated 11/11/18.
Bob
Nov 16, 2018 9:55 PM UTC
It sounds like the document has context rules turned off. Select Tools>Context Rules to see if context rules are on or off. If the document is out of context, context rules are automatically turned off. Select Tools>Check Completeness to find context errors.
Hope this helps!
Suzanne Napoleon
FOSIexpert.com
"WYSIWYG is last-century technology"
Hope this helps!
Suzanne Napoleon
FOSIexpert.com
Bobbert10-MarbleAuthor
Nov 19, 2018 1:22 PM UTC
That was exactly the problem.  The updated architecture doesn't like some of my customizations.  Thanks for your help.
