Dec 12, 2016 3:34 AM UTC
Styler page number start at attrbute value functionality fosi help
HI, I need to reset a page number according to an attribute valu, nfortunately the styler start at functionality is not working. I am still using the fosi engine, so no support.
I am trying to overide the fosi to fix it but am stuck. The attibute value is set on a chapter type element, and I am using an enumurat with setvalue=2 for folioct, with my fillval picking up the appropriate attname value and attloc, but it isn't working.
Has anyone else using Styler hit this problem and been able to implement a working solution?
Tracey
apco1-VisitorAuthor
Dec 12, 2016 5:08 AM UTC
BTW I am using sgml data using DTD Reference : ATA-TEXT//DTD CMM-VER8-LEVEL2
Dec 12, 2016 10:25 PM UTC
With native FOSI, the attribute value that is fillvaled into the enumerat with setvalue=2 must be on the top/first tag in the document. I don't know how it works with Styler.
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
apco1-VisitorAuthor
Dec 13, 2016 12:19 AM UTC
Hello Suzanne,
Thankyou, I found that little gem in your book   And added the @pgblknbr to the root element.
I have now applied the fillval and enumerat to a pgblk (chapter type) element and can see that it is picking up the attribute value correctly via a usetext.
However, I am unable to get the foliostr in the page footer to correctly pickup the foliostr from the element. The pgblk is also where I am applying the pageset (on the breaks menu) however I expect that the foliostr is being reset again in the pageset. I cannot seem to find anywhere in the pageset to insert the fillval?
Are you able to offer any further clues?
Tracey
Dec 13, 2016 1:31 AM UTC
I'm glad to hear Practical FOSI was helpful 🙂
If I correctly understand you, I suggest saving the counter to a different string variable and changing the footer to output that string. You may need an otherwise duplicate pageset for this purpose.
HTH!
Suzanne
