Support in order to use help
Hi!
I have been consulting Forums for PTC users, however in many threads
people give advice about read HELP X number. Where can I find this help?
also I would like to know if there's a guide where I can learn about how
to use the tools provided by adepter in forums.
Thanks in advance.
Paulette Zorrilla
    18-Opal
    November 5, 2012
    Hi Paulette--
    That notation, "help XXX", refers to a command you can type in the command line window in Arbortext to jump to a specific topic. To use it:
    1) If you don't see the command line at the bottom of your Arbortext window, go to Tools->Preferences, select the Window panel, and check the Command Line checkbox.
    2) On the command line, type "help xxxx" where xxxx is the referenced number. Then hit Enter, and your help center should open to the specified topic.
    HTH.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    pzorrilla1-VisitorAuthor
    Wow! Now I see. Thank you very much!
    Sorry about that, I'm pretty new 😃
