Aug 26, 2011 7:24 AM UTC
surroundContents() and losing track changes
Hello Adepters,
I wrote a function to wrap/unwrap a range in a special element. To wrap the range I use the range function range.surroundContents(element). To unwrap an element I replace the wrapped range by the actual range. Now in the function if I don’t turn track changes off the whole range is marked as added which I don’t want. If in the wrap/unwrap function I turn track changes off I lose all track changes I had in the actual range.
How do I wrap/unwrap a range in anew element without losing track changes?
-Samah
    18-Opal
    Aug 26, 2011 1:03 PM UTC
    Hi Samah-
    The AOM functions for modifying a range do seem to spread the change
    tracking markup around more than one might like. To get around this, you
    can try "cheating" and using the Acl object to apply ACL functions,
    which give simpler change tracking markup. For example, instead of using
    range.surroundContents(), make the range selected and then call
    Acl.execute("insert_tag {tagname}"). This will leave the existing
    content alone, and will only mark the tag insertion as a change. For
    removing a wrapper, position the caret at the beginning of the element
    (just inside the start tag) and use Acl.execute("delete_tag").
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    samah1-VisitorAuthor
    Aug 29, 2011 1:37 PM UTC
    Hi Clay,
    Thanks for your reply. The insert_tag() & delete_tag() worked perfectly.
    -Samah
