8-Gravel
Nov 27, 2018 8:28 AM UTC
svg export in IsoDraw faulty
- 2 replies
- 3100 views
- Translate All
Hello!
Most recently, I used Isodraw 7.3 in the M040 build 6. An svgz export has worked flawlessly in this version. Now my system was changed to Windows 10 and with this came an Isodraw update to M080 build 6. Since this svgz export does not work correctly anymore. Hotspots created in Isodraw are displayed twice in the svgz, which means that the online spare parts catalog can no longer display the correct item numbers!![]()
I attached screenshots to this problem in a Word document.
About help and solution suggestions, I would be very grateful!: smileyvery-happy:
Best regards Mirko
