Apr 19, 2016 1:14 PM UTC
symbol drop-down list is empty for schema
We have recently changed from DTD to a schema. Since doing so we have lost our entities/symbols from the drop-down list. From what I have read on this forum site, it appears that PTC has not made an atempt to resolve this issue. I am wondering if anyone has come up with a solution. I would appreciate if anyone could provide a few suggestions. Thanks
    18-Opal
    Apr 19, 2016 2:42 PM UTC
    Hi Kathleen--
    You can work around this using some ACL code. In your editinit.acl file, add the following:
         require _findentdlg;
         set entitylist="...";
         _findentdlg::_updateEntityList(current_window(),current_doc());
    Replace the "..." with a space delimited list of entity references. With a schema, you won't have named character entities, so you'll have to use numeric entities, for example if you want to include the copyright and trademark symbols, it would look like this:
         set entitylist="© ™"
    For some reason, just setting the entitylist option string won't update the droplist automatically, that's why you have to use the _findentdlg::_updateEntityList() function to do that.
    --Clay
    18-Opal
    Hi Kathleen--
    --Clay
    May 30, 2016 1:52 PM UTC
    Sorry it took me so long to respond...just tried it now and it works perfectly. Thanks a bunch!
    May 27, 2016 3:41 PM UTC
    Hi Kathleen,
    Did Clay's answer help you get this resolved?
    Let us know if you need additional help!
    May 30, 2016 2:34 PM UTC
    Yes - it worked perfectly!
