Sep 16, 2010 3:38 PM UTC
Table FOSI formatting?
I thought CALS table properties were "automatically" recognized. Within
the editor, I have changed the width of my table to less than a page wide.
This displays as expected in the editor. I then test the composed view and
the table fills the column width. It seems I can change the proportion of
the columns, but I can't get the overal table width to change.
I've set/unset the pgwide value to see if this affected anything - no
difference. I've alos used the table properties which inserts a PI - this
had no chnage.
Any idea what is going on?
..dan
    Sep 17, 2010 2:19 AM UTC
    I think you may have found a bug that affects authored tables and well as
    FOSI-generated tables.
    In the Table Properties dialog, there is a check box for Use Default (100%),
    which if checked means the table will be as wide as the Edit window and will
    fill the page width in composed output. If the check box is not checked, the
    Display Width property is un-grayed so you can enter the desired width of the
    table. This is recorded as a PI such as the following:
    I expected this PI to work in a gentable. However, when I tested it in a
    one-column table in 5.3, the table was as wide as the page width and did not
    honor indent settings.
    When I specified the colwidth as 20pi, the table was 20pi wide in the Edit
    window and in composed output.
    Then I tested specifying the width for an authored table and leaving the column
    widths proportional, and the table had the correct width in the Edit window, but
    in Preview, it was margin to margin. As with the gentable, specifying the column
    widths worked in the Edit window and in Preview.
    Hopefully this is fixed in 5.4, which I don't have so I can't test it. If anyone
    determines it is not fixed in 5.4, would you please do everyone a favor and
    bugreport it to Arbortext technical support?
    Thanks!
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!"
    -----End Original Message-----
    Sep 17, 2010 3:10 AM UTC
    >it. If anyone determines it is not fixed in 5.4, would you please do
    >everyone a favor and bugreport it to Arbortext technical support?
    I'll check on Monday, I'm currently working in 5.2
    ..dan
    Danny Vint
    Panoramic Photography
    Sep 20, 2010 5:18 PM UTC
    In Reply to Suzanne Napoleon:
    Thanks!
    Suzanne Napoleon
    www.FOSIexpert.com
    Sep 20, 2010 7:15 PM UTC
    First reponse back from PTC is that this is as intended. If you drag the
    column markers and outer edge of the table you are setting propertional
    values and even with "Full width" set to off, it is going to make the
    table the full width.
    If you edit the column properties and set them to a fixed width (3in
    instead of 3*) then the table does respect the sizing information.
    I indicated that if nothing else this was counter intuitive when
    everything about he editor interface indicates that the table will be
    smaller than the width of the page. For instance, the editor view shows it
    less than the width of text on the screen, table rules shows it as 3
    inches, and properties says use a specific width and not full.
    I'll let you know how this plays out.
    ..dan
    > column
    > window, but
    > column
    > anyone
    > and
    > Thanks!
    > Suzanne Napoleon
    > www.FOSIexpert.com
