Aug 20, 2015 7:29 AM UTC
table height
In Footer . I am Not able to Reduce the Table Height. Is there any way reduce the default row height.
K.K
    Aug 21, 2015 11:11 PM UTC
    Hi Sridhar,
    Could you provide the Community a bit of specifics on your situation?
    You mention footer, so this is in the stylesheet, right?  Are you using FOSI or Styler?
    Have you inserted a table in the footer section, and are trying to modify it?
    Perhaps a screenshot of the footer section as currently defined might help.
    Rafael
