bfriesen
18-Opal
Sep 15, 2011 8:38 PM UTC
template layout changes when clicking on the referenced link
I am wondering if this is normal behavoiur for arbortext 6.0 M010, IsoDraw 7.2 F000. I have referenced a procbody from a different sma side by side procedure (customized) in my current document. when in the current document everything looks ok. If I click on the the procbody link and it opens the referenced section the layout goes all crazy. It seems to do it with any cross referenced procbodies.
Anyone else have an issue like this.
    Oct 28, 2011 9:03 AM UTC
    Just in case the question is still relevant...
    If you open the "tm_M205_hood_lower_position_closing.dita" separately, using File-Open, is it displayed correctly?
    bfriesen
    bfriesen18-OpalAuthor
    18-Opal
    Nov 1, 2011 2:17 PM UTC
    No it does not seem to make a difference until I shut down arbortesxt and restart it then it works like you would expect until I go and look at a different section by clicking on the content reference. Then the referenced section will be messed up until you restart the program.
    Bryon
