Jun 10, 2014 8:54 PM UTC
Text Alignment
Hi everyone,
I've been facing an issue regarding text alignment. I've included an example of what our text looks like below:
Is there any way to make the text all line-up under the "you" at the beginning? It should look like the text below:
WARNING: YOU MUST MAKE SURE THAT YOU CAN
HOLD THE RADOME BEFORE YOU REMOVE/
INSTALL IT. THE RADOME IS HEAVY. IF IT FALLS,
IT CAN CAUSE INJURY TO PERSONNEL AND
DAMAGE TO THE EQUIPMENT.
I've also included images of the FOSI below:
    Jun 11, 2014 5:21 PM UTC
    With FOSI, this is done with a hanging indent and a kern-to, which is like a tab stop. For example (in pseudo-code):
    e-i-c gi=warning
    indent inherit=1 firstln=*-4.5pi leftind=4.5pi
    usetext source=\WARNING:\
    e-i-c gi=para context=warning occur=first
    usetext source=@4.5pi
    This approach is also used for hanging lists.
    2-Explorer
    Jun 10, 2014 9:05 PM UTC
    The simplest (probably) is two separate pieces of text. Place one offset and reference the other to keep them together.
    Jun 11, 2014 7:34 AM UTC
    In APP you can handle this via the "relative indent" function <?ri>. In FOSI you should use the "side by side" feature.
    e-i-c gi=warning
