Jul 13, 2015 10:14 AM UTC
To Fetch PTC server system Attributes in Image element in XML
twowaymetadatarule doesnt support for graphic object ,but PTC Server system attributes can be pulled into XML documents via ACL
Below is the Logic implemented:
init.acl
function initialize() {
utils::initHooks();
initialize();
utils.acl
initialize callbacks to handle CMS session handle
function Callbacks() {
  sess_add_callback(SIM_SESSHDL, "checkin", "utils::checkin_callback");
  sess_add_callback(SIM_SESSHDL, "create", "utils::create_callback");
function checkin_callback(dobj, docid, ud) {
local firstoid = dobj_first_oid(dobj);
local checkindoc = oid_doc(firstoid);
graphicnumber(checkindoc);
doc_save(checkindoc);
  return 0;
function create_callback( name, folder, opts, first, last, version, objtype, ud ) {
    local doc = oid_doc(first);
  graphicnumber(doc);
  doc_save(doc);
  return 0;
function graphicnumber(doc)
// write your business logic to get windchill no
something like
local number = dobj_get_attr(imagedobj,"WC_NUMBER_ATTR");
