TOC: How to format page numbers?
Hi!
I've searched for hours now, but I don't find a way to format the display of page numbers after each chapter in the tabe of contents. I'm pretty sure this is possible, but if I try to add user defined formats in the table of contents, I only can change the number of the chapter and the text title. Can anybody give me a hint?
Thanks and regards!
    Hi there,
    Are you using Styler for the formatting? If so, you will want to look at styling the SFEs (Styler Formatting Elements). These are automatically generated by Styler and are hidden by default. You can enable them in the preferences in order to view and modify their behaviour.
    BTW, there are also UFEs (User Formatting Elements) and GTEs (Generated Text Elements) which you may encounter and need to style in a similar fashion to SFEs.
    -Gareth
    Hi there,
    -Gareth
    Hi Gareth,
    Thanks for your answer! That worked well!
    Yes, I've tried to handle this with UFEs and GTEs in the fist place, but the result wasn't very good.
    kind regards
