7-Bedrock
March 14, 2023
Toolbars from IsoDraw 7.3 to 7.4
  • March 14, 2023
  • 2 replies
  • 2558 views
Hi Gang,
Just updated to IsoDraw 7.4 trying to set things up and had a couple of questions. Where are the toolbars located in 7.3 and where should they go in 7.4? Where should the ISM files be located in 7.4? I have accumulated several macros over the years and want to be sure I can access those files.
 Is there a file high archy located anywhere so I can see the file structure of IsoDraw?
Keith
Best answer by bfriesen
Look here for the isodraw files
C:\Users\username\AppData\Roaming\PTC\IsoDraw
Templates
I have found that template files can be stored  in the C:\Users\bfriesen\AppData\Roaming\PTC\IsoDraw\Templatesthere or  in the install folder C:\Program Files\PTC\Arbortext IsoDraw 7.4.0.0\Program\Templates if they are in both they will show up twice.
Macros
I have also found that you can store your macros in a networked folder, if you place a shortcut the store folder in the install folder C:\Program Files\PTC\Arbortext IsoDraw 7.4.0.0\Program\Macros\
I have put in a product improvement to allow the templates to operate just like the macros. WOuld be nice to have the templates in a central location for all users to access.
Bryon
bfriesen18-OpalAnswer
18-Opal
March 14, 2023
Templates
Macros
Bryon
khoward7-BedrockAuthor
7-Bedrock
March 14, 2023
Thank you Bryon.
