Nov 21, 2014 9:57 AM UTC
Trail version for EMC Documentum repository connector
Hello All,
I am new to PTC Arbortext editor.
I need to install trail / evaluate version for Arbort text editor for following.
1. Need to create the templates - using Editor tool / Do i need styler or editor ?
2. Need to create re-usable components and store in Documentum repository.
3. Publish to PDF.
Reequest you to le me know, can i get trial version of above fetaures component like styler / editor , publishing tool and Documentum repository connector.? if yes, from where can some provide link for the same ?
Which version of documentum content server / repository will be compatible.
    TimPhelpsAnswer
    Nov 24, 2014 1:45 PM UTC
    Downloading the zip file from the PTC website to the Arbortext Editor client machine, I get a zip file.
    MED-71939-CD-061_M030_Win64.zip file
    Extract that into a temp directory I see 4 directories created
    docs, flexlm, server, windows
    The content of the server folder needs to be installed on the Documentum Serve
    In the Windows folder is a setup.exe file used to install Arbortext Editor.
    The docs directory contains installation instructions and release notes.
    The flexlm directory contains the license manager.
    Nov 21, 2014 10:19 AM UTC
    Link is here: http://www.ptc.com/product/arbortext/author/editor/evaluation
    List of compatible softwares are in the product documentation. Also I heard from the next version they will discontinue support for the Documentum adapter.
    mkothari1-VisitorAuthor
    Nov 21, 2014 11:05 AM UTC
    I saw that Downlaod.. but trail version has all the things which I am looking for ?
    2. Plugin - Store in Documentum repository.
    3. Publish to PDF.
    Thanks .. that location seems to have only 1st point from above not Documentum connector ? can you confirm once. Also where can i find the guides for Documentum conenctor to crosscheck the same for supported version of DCTM.
    Thank you for important note of from next version going to remove DCTM support.
    Nov 21, 2014 11:31 AM UTC
    Arbortext 6.1 trial ships with the Documentum adapter. The trial version also includes Publish to PDF as a desktop function (this is a feature of Styler). That is to say, you cannot integrate Styler with Documentum to have it automatically produce renditions from your CMS objects. For that functionality you would typically use Arbortext Publishing Engine.
    It is worth noting that Arbortext Editor and Arbortext Styler are essentially the same software, but Styler allows you to publish to web, PDF, etc. whereas Editor is purely for XML authoring and editing.
