Apr 29, 2011 6:39 AM UTC
Translating DITA projects, XML:TM & XLIFF & Arbortext Editor
Is it possible to use the benefits of XML:TM and XLIFF with Arbortext Editor?
How do you keep track of modified content to be sent to translation services?
How do you upload the translated topics in Windchill?
Localization
A. avoiding to translate parts of a document previously translated and not modified
C. obtain translation information from the translation services in order to satisfy the first entry of this list and making less painful switching translation agency
Embedding translation memories and hints into the xml document itself
http://www.xml.com/pub/a/2004/01/07/xmltm.html
1. ICE, In Context exact matches or "perfect matching"
2. In document leveraged matching
3. In document fuzzy matching
III. XLIFF
http://www.xml.com/pub/a/2004/01/07/xmltm.html?page=2
http://www.maxprograms.com/articles/xliff.html
A database containing aligned pairs of source and target language segments from unspecified documents
Same segment. Proofing is required since the context can be different
Same segment with some different words.
    Apr 29, 2011 1:30 PM UTC
    Personally, I'd recommend not relying on XML:TM or XLIFF. Using a software, such as Trados, the already translated words are just inserted. So basically, you take the entire document and run it through your translation software. If parts have changed and need translated, they are accounted for. Then make sure your translator/s have the same database as your translation software and they will only have to translate the words needed.
    Trevor Hendricks<">mailto:->
    Senior Technical Writer
    Technical Publications, MS: 078
