Nov 26, 2014 10:36 AM UTC
trial license - HOST ID is not valid
I have downloaded the trial version of PTC Arbortext Editor with Styler. The program ask me for the (trial) license key. I tried to obtain the trial license using the PTC website, but the procedure fails: PTC website said me that the HOST ID of my PC is not valid. My hostID begins with "90-1b". How can I solve this problem?
I sent an email to - but I've not received a reply.
Dec 2, 2014 10:53 PM UTC
FYI we had this same problem with a trial license recently, and PTC Support managed to resolve it.
Nov 26, 2014 10:50 AM UTC
Hi Matteo,
How are you obtaining your HostID?
You could try looking at your Network adapters MACid details in use and if it is different try this instead?
See: Open Network and share cntr > Local Area Connection > Details > Pysical Address ...
Regards
Chris
______________
www.tformat.com
PTC Arbortext Specialist Resellers
Nov 26, 2014 1:04 PM UTC
On the PTC Support web site, the licensing web tool steps you through the process of configuring your software to your hardware. You need a PTC.com web account login, your Customer Number, and your Host ID code unique to the computer. You can get the Host ID:
  • by running cpu_id.exe from a Windows command prompt (available from the flexlm directory on the installation DVD or download zip or from the PTC support site).
  • the first time you run Arbortext software, if it can’t obtain a license. The Licensing Error dialog box will prompt for license source information and provide the Host ID for the system.
  • by going to the following web page on the PTC support site for instructions:
Nov 28, 2014 10:33 AM UTC
I follow this procedure:
- I read my ID from cpu_id.exe
- I logon on the PTC Arbortex website.
- I fill the web form of the Arbortext evaluation license, at the following address:
http://it.ptc.com/appserver/lm/programs/index.jsp?program=epiceditor
- When I press "submit", the web site tell me that "your HOST ID is not valid"
My ID begins with "90". In the help page "Determining a Machine's HOST ID" there is a note:
"A valid hostID on a Windows machine has historically begun with either 00 or 08. However it is becoming increasingly more common with newer machines that a hostID from a valid source may begin with some other combination of numbers which may be recognized as invalid by PTC License Management tools. An example of this might come from a newer wireless card. If this is the case please contact PTC License Management or PTC Technical Support for assistance."
So, I think this is the problem.
Dec 1, 2014 12:05 PM UTC
I would suggest contacting PTC's support.
Either submit a case or call 800-477-6435.
Select licensing.
