bfriesen
18-Opal
Jul 27, 2020 3:02 PM UTC
trying to shorten a path in siteprefs to see file in unzipped application folder
We have a menu file that we are trying to call up, using the siteprefs file. It should get the menu file from the unzipped application folder, but I cannot figure out what the path should look like. The file is located in the custom\lib folder. If I enter the entire path I can see the menu. But that does not work for my other users then.
<Variable name="APTMENUFILE" value="..\custom\lib\menu.cf"/>
</EnvironmentVariables>
Bryon
Dec 1, 2020 8:48 PM UTC
I don't know where you are using the menu file, but would the ACL get_custom_dir() help?
If you are overwriting the main editmenu.cf that would be used at startup, then I think you may be able to just specify "menu.cf" and it will find it in the custom folder.
