Two Simple XPATH questions
<tag1>
<tag2></tag2>
</tag1>
If I'm in tag2, how do I access tag1? I tried ../tag1[1] and parent[1]
And also, how would I access the first element from an att with XPATH? For example, this didn't work:
<e-i-c gi="code" occur="all">
<att>
<specval attname="code[1]" attloc="#xpath" attval="1"/">
<charsubset>...</charsubset>
</att>
</e-i-c>
    Hi Caroline,
    On further reflection, I'm thinking the problem may be that the e-i-cs are not in the correct order and are not being matched properly. If occur=all is listed first, it will always be used and other occurrences will be ignored. (This may be my least favorite thing about Styler.)
    Good luck!
    Suzanne
    cleccese1-VisitorAuthor
    Thanks Suzanne. I added in a last context and now it's working fine. Sheesh!
