Jan 5, 2015 10:44 AM UTC
Unable to find license key for trail version and CMS connector details
Hello All,
I have downloaded and setup the Arbortext editor trial version and trying to configure the CMS (Documentum) need following document, can someone provide the same unable to access.
http://www.ptc.com/WCMS/files/138341/en/cms_guide.pdf
Also, did not find the trail version / license key to configure to perform following steps.
You will use the PTC License Landing Page to configure the PTC Arbortext
software licenses for your hardware.
1. Go to the PTC support page at http://www.ptc.com/support.
2. Choose Arbortext.
3. Choose Arbortext License Support and log in to your PTC account when
prompted. You will need your login name, password, and Customer Number.
4. Choose your Product Family from the list.
5. Choose the Version from the list. The Hardware Selection is then displayed.
6. Enter the PTC Host Id (available by following the directions at the beginning
of this section). If your computer is already in the system, you can Browse for
it.
Enter the name for your computer in the Host/Triad Name.
The PTC Host Id and Host/Triad Name identify one of the following:
• A single computer for a node-locked license.
• A single computer that will be serving floating licenses to end users.
• A set of three computers (called a triad license server) that will be serving
floating licenses to end users. This type of licensing provides server
redundancy.
Click Continue.
7. If the Host ID is not in the PTC licensing system, you will be asked to enter an
installation address and contact that will be associated with the Host ID.
8. Confirm the combination of PTC Arbortext software and your hardware for
your license. Then click Get License. You will get a call number for
confirmation of the request.
As I am using trail version, do not have appropriate customer login to perform the above steps.. does any one know how to get trail version.
Jan 9, 2015 12:24 AM UTC
This is a common problem, I don't know why PTC have not corrected the web site. You need to contact PTC directly with your Host ID. See recent thread here: http://communities.ptc.com/thread/58729
Jan 7, 2015 5:57 PM UTC
When you downloaded the software from the Free Downloads page there is a form that needs to be completed so PTC can send a trial license. The link is: http://support.ptc.com/appserver/mkt/products/tryout.jsp?&wcms_id=134918&hostid=null&program=epiceditor&campaign=null
Have you completed this form and still not received your license?
Please feel free to contact me directly so you can begin your evaluation.
Susan
Susan Fort
Solution Manager, Aerospace and Defense SLM Segment
T 937.743.6356 F 781.707.0602
M 937.707.0302
E
mkothari1-VisitorAuthor
Jan 8, 2015 5:03 AM UTC
When I Submit the details with following Host ID (machine on which PTC Arbortext Editor with Styler is installed).
PTC HOSTID = 00-50-56-BA-01-2B
Above is generated using cpu_id.exe as per installation documents.
Getting message as INVALID HOST ID.
Also, I am looking for following document , unable to access.
Thanks in advance!
